Left blinker stopped working tonight
Old 07-12-2008, 09:39 PM
Shackleford's Avatar
Default Left blinker stopped working tonight
I noticed that the left arrow stopped blinking and didn't hear any ticking either. It's just a steady light now. What's the deal?
The hazards still work/flash, though.
Old 07-12-2008, 09:45 PM
usaf_hess's Avatar
both hazards work? have you walked around the car with the hazards on and seen all 4 blinking? my guess would be the relay if it still doesnt work with the hazards on or the left hand blinker its the relay more than likely. if it works with the hazards on but not the turn switch then it is your switch. my guess.
Old 07-12-2008, 09:47 PM
I walked around the back and saw the rear hazards working. I forgot to check the front. My initial thought was that the turn signal relay went out. Where exactly is that? Underneath the dash?
Old 07-12-2008, 09:52 PM
usaf_hess's Avatar
there should be a panel in the engine bay where the relays are mounted i think on the battery side but i havent really looked before so dont quote me. the hazards and turn signals run on dedicated relays or do they run off the same one? <--im not sure about that but if they are on dedicated relays and if the hazards work which if the rear worked than the front do as well than your turn signal relay is out just pull the relay box lid find the relay pull it put some die-electric grease on the new relays connectors and push it in the spot button everything up and your gold.
ON EDIT: i re-read your post and if it is a steady green arrow your switch is fine and your relay is out.
Old 07-12-2008, 10:00 PM
Would a parts store carry the relay? Where else could I get it?
Old 07-12-2008, 10:09 PM
usaf_hess's Avatar
auto zone most definatly will have it others that might could be checkers, o-reilly's, dealership i think any parts store will have it if they dont they could tell you who might.
Old 07-12-2008, 11:34 PM
Texfinn's Avatar
No need to change any relays before you check whether your front left turn signal is working or not.
I'm pretty sure you'll find your problem right there.
Old 07-12-2008, 11:36 PM
I just finished checking everything. The front left and rear turn signals do not work. The front left hazard doesn't work either.
So, what do I replace?
Old 07-12-2008, 11:39 PM
98catfish's Avatar
you need to check the blinker fluid! LOL just kiding
Its The front bulb!
Old 07-12-2008, 11:44 PM
Its The front bulb!
How is it the front bulb? Isn't that a pain in the butt to reach?
Old 07-12-2008, 11:56 PM
Texfinn's Avatar
Replace front left turn signal bulb and you're good to go.
Old 07-12-2008, 11:57 PM
Where can I get that? Vatozone? It's the clear one, right?
The lights are still on - they just don't blink.
Old 07-13-2008, 12:42 AM
jebuzws6's Avatar
its your front bulb make sure its the yellow bulb and you connect it rigth to the wiring harness if it just lights on and does not blink just jiggle the bulb a little till starts to blink ... there is no need for a relay just your bulbs
Old 07-13-2008, 12:44 AM
I see. I haven't taken a look at it, but how can I get to it?
Old 07-13-2008, 12:47 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Its The front bulb!
F'N BULB.....Panel underneath ==2 screws + flap===reach up and turn socket...[squeeze tab] and turn...replace bulb....
jebuzws6's Avatar
stick your hand in the bottom opening under the white light and judst twist the wieing harness .. is sort of like a clip desing that you have to press with your thumb and than turn..
Old 07-13-2008, 12:48 AM
Sweet. I'll do it tomorrow. I'm assuming Vatozone carries the bulb.
jebuzws6's Avatar
no need for screws just your hands dont even need any tools
Old 07-13-2008, 12:49 AM
jebuzws6's Avatar
never heard of Vatozone but Autozone those part number will be somethin like 3754 or 3750 something along those lines
Old 07-13-2008, 12:50 AM
NHRAMAN's Avatar
Exclamation
This way is correct also--but u are doing it blindly then....
