power window buttons...
Old 07-12-2008, 10:12 PM
toofless916's Avatar
Default power window buttons...
The power window buttons on the driver side have sunken into the door handle. I can no longer raise or lower my windows because I can't get to them. Is there a write up on how to fix this?
Does that panel just pop off and on?
Old 07-13-2008, 10:25 PM
Old 07-13-2008, 10:33 PM
2002_Z28_Six_Speed's Avatar
So basically you broke the switch panel cover? Plastic piece that holds the switches into the door panel?
Old 07-14-2008, 11:16 AM
qwk93ta's Avatar
You can buy a switch panel ( not sure of the actual name ) at most GM dealerships for under $20, it's not hard to replace either.
Old 07-14-2008, 11:35 AM
dorifto83's Avatar
yes it does. mines dropped in and i just pulled it out, pushed it back into place, and used the wires as a cushion so it doesn't fall in again.
Old 07-14-2008, 04:01 PM
Thanks man...imma go check it out right now..
Old 07-14-2008, 06:10 PM
Switch panel covers are discontinued as far as I know. Where did you get them?
Old 07-17-2008, 03:48 PM
yup...i need a new switch panel cover...does anyone have a part number or a website i can order one from???
Old 07-17-2008, 04:49 PM
I tried Classic Industries and they have some parts but not these. I didn't call them to verify just checked the online cat. Most likely bet is E-Bay. The dealer says they don't have them. You might get lucky and find an online dealer that has them if you call around.
Old 07-17-2008, 06:38 PM
SparkyJJO's Avatar
What about the clips for the panels? I was told that the dealer has those but if they don't have the panel then is the clip not available either? Because I need one, car came with one missing somehow so the panel pops out all the time.
Old 07-17-2008, 08:11 PM
Hmmm is the panel cover marred up so that if you put a new clip on there it would come off again?
I think I might have one but I would have to dig for it.
Old 07-17-2008, 09:19 PM
SparkyJJO's Avatar
It is scratched a little bit but otherwise looks normal. It looks like he took the panel off to check the wiring (when I got the car the driver motor was bad) and in the process of removing the panel lost the clip somehow.
