Radiator Problem...
Radiator Problem...
So I finally found where my radiator is leaking from. There is a small crack in the filler neck of the radiator about 2 inches below the coolant level sensor. So every time I add coolant, it drains to where the crack is, causing the low coolant light to come on. My question is, is there any way to fix the crack in the plastic filler neck? Or do I have to buy a completely new radiator? Thanks.
