Getting A Clunk In Rear Suspension...Please Help!!!
Restricted User
When driving, if I hit a bump I'll hear a clunk/pop out of my rear suspension. It also occurs if I'm in neutral and I hit my break and let off. It's sounds like my rear is moving. I took a look under the car and everything seemed to be alright. I have Sphon Adjustable LCA's, PHR, and TA. The TA was my first suspect. I checked it and it looked alright...I need to figure out what I need to fix. I want to get to the track as soon as I can so any info would be great.
-Dave
btw the car is an M6
-Dave
Did you get under the car and move the trans mount? If could have broke only way to make sure is to get under the car and put a big screw driver and try lifting it apart after you lift the transmission a little bit with the jack.
