Air pump removal
Old 08-12-2008, 08:37 PM
kraemer94's Avatar
Default Air pump removal
I had my air pump programed out. I started to remove all the air pipes. Do I need to do anything to the solenoid on the driver side that the air pipes had been plug to? I also notice that there are two small tubes connected to the solenoid.
Old 08-12-2008, 09:02 PM
jsteele90's Avatar
all i had to do was put a small vacumn cap on the port that the small vacumn line came off of.
Old 08-12-2008, 09:18 PM
kraemer94's Avatar
Here is a pic of what I'm talking about. It's that little pipe on top of the solenoid
Old 08-12-2008, 09:20 PM
nemss1's Avatar
i removed the solenoid on mine
Old 08-12-2008, 09:22 PM
kraemer94's Avatar
What did you do with the pipe. Cap it?
Old 08-12-2008, 10:29 PM
jsteele90's Avatar
take the big black thing off and the vacumn line. put a cap on the small solenoid thing that has the wiring harness running to it. very simple
Old 08-12-2008, 10:37 PM
nemss1's Avatar
i removed the solenoid and vaccuum lines completely. there should be a vaccuum line that run from the solenoid to a vaccuum T-fitting on the back of the intake. i removed the line and put a cap on the T
Old 08-14-2008, 08:29 AM
kraemer94's Avatar
Thanks guys!
Old 08-31-2008, 02:34 PM
kraemer94's Avatar
How do you remove the solenoid? I tried today. I see there is one nut on the side holding it I removed it but there must be another one on the back that I can not see.
Old 08-31-2008, 02:41 PM
Michael02hawk's Avatar
I guess its just me, but when I removed my AIR system, insetad of caping off the stray vacumm line, I instead removed the 'T', and extra line. Then plugging the now open vacumm line directly into the intake.
No caps, no T's, no stray lines - a direct clean fit.
Old 08-31-2008, 08:52 PM
kraemer94's Avatar
How did you remove the solenoid?
Old 08-31-2008, 09:16 PM
Bad06SS's Avatar
I could really use some more info here. Can you take any pics? I'm going to remove my air pump soon, and want to make sure that I've got it all worked out before I start. Thanks!!
Old 09-01-2008, 06:58 AM
Once you get back in there, you'll see what I'm talking about. Real easy to do...pop the vaccum like off of the 't' (keeping the little boot on the line) then plug that line w/boot into the intake manifold....and wola, factory like design.
