97 z28 steering probs
I have a 97 Z28 and i have inherited a steering problem .. It has started having lock ups of the steering when i go to turn.. It will turn if you put all ur power into turning it then it may just break loose and u oversteer when it breaks loose .. Here is what i have done to it and it still has this problem .. New power steering pump,new rack&pinion new tie rod ends and even new struts which have noting to do with problem but i was under there soooo.. the system was bled but has some metal flakes in it .. So if anyone has a thought let me know as it is very dangerous and anoyyyyying ...
