weird steering column stuff
Old 08-17-2008, 05:57 PM
AxisOfOil's Avatar
Default weird steering column stuff
Okay... so, at first, i thought my high beam switch didn't work when i got my Z.
today, i figured out how to turn them on... and it involves something that's been bothering me about my steering column for a while.
when I pull down on the wheel... it moves about two inches to the left and about an inch down, and will spring back up when i let go.
when i have it pulled down, i can activate/deactivate the highbeams, and also use the ACC position with the ignition (turning it to the left so the stereo and such turn on without the ac, vents/dash lights, etc)
what's wrong with my steering column? this is so confusing...
Old 08-17-2008, 07:44 PM
RCowan's Avatar
About the thing moving down and sideways... I would check the mounting bracket for the steering column? Not sure.
About the high/low beam switch-- on a lot of old GM cars the switch moves a little over time so that it will only work when you have the wheel in a certain position. This is easy to fix. If you pull off the trim panel and look up under there you will see a metal rod that moves along the column as you actuate the stalk with your hand. At the end of that rod down the column you can see where it is trying to click the switch. The switch is mounted to a bracket on the top of the column. You have to loosen the two things that hold it on. I think one is a nut, one a screw, I don't remember but you have patience and contortionist skills to get them. You loosen them, push the bracket toward the steering wheel just a millimeter or 3 and then tighten them both down again. Now your high/low switch will work in every position. Push it, tighten one nut, test it, and tighten both if ok.
That being said, with that crazy down 1 inch, left 2 inch behavior you are describing, I would first check all the mount positions on the column--at the firewall and the bracket holding the whole thing up. Sorry I can't thing of anything else--maybe someone hit the wheel in a fender bender??
Old 08-17-2008, 09:41 PM
2002_Z28_Six_Speed's Avatar
You are correct. The actual switch is on slotted holes and you can adjust it but it is very hard to get to on a stock car. I have pulled alot of now unsed wires and it isn't much easier. There is no adjustment up top or in the column for the high beams switch. It is by where the column harness plugs into the body harness.
The issue with the steering wheel moving to the left and down is known. I will try to work on a solution sometime in the future. My car and several others I have seen have had this issue. I think it may be related to the car being wrecked in the past because all the cars I have seen with this issue have been in some kind of serious wreck. I think it may be a "replace a part and it's fixed issue." Maybe caused by the airbag inflating or the streering column being subject to force?
I am just not sure what to replace because I haven't done this yet.
Old 08-18-2008, 02:25 AM
AxisOfOil's Avatar
...according to carfax and carchex, there wasn't a serious accident in the car's past.
idk though... the dealership seems like it's lied to me more and more every day. i finally got the number of the guy who owned the car before me... time to get some real answers
Old 08-18-2008, 01:18 PM
BigZee71's Avatar
The steering wheel is moving because there is a bolt or two in the joint that have backed out. They will back out against something and not come out anymore so it wont get worse. I beleive you have to take the wheel off and take the column apart to fix it.
All 3 of my fbodies have done this. None where wrecked.
Old 08-18-2008, 06:25 PM
Thank you for the update on this!! Maybe the fix is simply locktite!
Is there any chance you could ID what you touched in this diagram? It would help I am sure! Thank you.
Attached Thumbnails weird steering column stuff-steeringexplodeddiagram9802passtiltdomesticsir.jpg
Old 08-19-2008, 12:16 AM
AxisOfOil's Avatar
after my 1400 miles tomorrow... i'll check it eventually... i'll post back if this is the solution
Old 08-19-2008, 07:07 PM
99345hp's Avatar
I believe its Items 15. There are 3 or 4 screws that have reverse torx heads on them. Ok, to get to them is the fun part.
1. Disconnect battery for 10 min before starting.
2. Remove steering wheel
3. Remove nut in center of column followed by the horn switch.
4. Press and hold in the metal plate while removing the snap ring holding it down.
5. Remove the turn signal switch. You shouldn't have to remove it all the way, just unplug the wires under the column and pull until it will hang out of the way.
6. Ok you should be able to see the screws now. Remove them one at a time and place loctite on the threads and replace them.
7. Reassemble.
Old 11-26-2011, 06:16 PM
AxisOfOil's Avatar
7. Reassemble.
So... to bring back an old, dead, and gone thread... I finally fixed the problem today.
Everyone was partly correct and partly wrong!
The down and to the left problem is caused by part 39 on the driver's side, popping out. It's not a screw, and it's not backed out. It's just a pin with a shoulder and a cap, and it needs to be hammered back in after removing part 39 on the driver's side (it just pops out... wiggle it with a screwdriver or thin punch while you move the wheel up/down). You will have to pull the wheel down and center it to put the part back in. Then just slide the passenger side back in and reassemble.
I figured I would update this in case anyone else finds the thread and wants to know if there was ever a solution.
Old 11-27-2011, 02:01 AM
slowpoke96z28's Avatar
i thought it was the callout #61 bolts that may loosen. do you have any pics of what you did?
Old 11-27-2011, 02:09 AM
gs462's Avatar
Car fax car check CAR ANYTHING will not show it if the shop that fixes the car doesn't report to them. Carfax is a JOKE.
Old 11-27-2011, 02:11 AM
gs462's Avatar
Id like to see pics also.
Old 11-27-2011, 05:37 AM
Pony Exp.305's Avatar
at #56 different length? I think about want more length longer
Old 11-27-2011, 10:21 AM
a machine shop could make one, but thats the whole reason the seats move. plus, depending on how far you wanted to lengthen it, you would have to modify the clock spring or else you'd lose all the electronics in the steering wheel
Old 11-27-2011, 11:53 AM
AxisOfOil's Avatar
...nope. I was quite frustrated by the time they finally went in that I wasn't about to pull them out and take pictures. SORRY.
But, to get to them:
Remove the steering wheel
Remove the SIR coil/clockspring
Remove the lockplate
Detach the white turn signal switch mechanism (don't forget the hazard switch)
Remove the #15 and #18 screws, and pull the ignition cylinder out of the column
pull the cowling towards you about an inch
the two pins should be visible at 3 and 9 o'clock.
Old 11-30-2011, 10:32 AM
aquariussuperman's Avatar
Thanks for posting this. I assume you need a steering wheel puller or do normal garage tools do the job? thanks.
Old 11-30-2011, 12:15 PM
AxisOfOil's Avatar
Yeah. Steering wheel puller. A logo plate remover and snap ring pliers are useful, but bit required if you have some picks and very strong fingers.
Old 11-30-2011, 05:47 PM
an impact makes nice easy work of the nut holding the steering wheel down too. never took one off without access to an air compressor, so idk how hard it is to do by hand...
Old 11-30-2011, 05:52 PM
AxisOfOil's Avatar
Mine came off pretty easy with just a little craftsman 3/8" ratchet and the appropriate socket.
No cursing or even grunting required.
Old 03-10-2013, 03:01 AM
jbald's Avatar
I actually tore into my column and found diagram part number 62 be at fault. It has two ears that the dowels fit into. One became wallowed out. I didn't bother to research whether or not you can even get the part. However, I took the column down to this part and removed it. I flattened the top of the 'ear' in question to allow for drilling and tapping it for a makeshift set screw of sorts. The bolt needs to be small and it took some time, beers and expletives to get it to work. As far as I can tell it cured the issue. I still need to put the column back in. I will update with final results soon. If it does work I will try to post pics of another column that needs the same repair to illustrate my method. Its a simple enough idea but a real ***** to pull off due the severe lack of space allowed upon reassembly.
Quick Reply: weird steering column stuff
