AMSOil
Old 08-21-2008, 08:09 PM
CETAWS6's Avatar
Default AMSOil
I'm thinking about using AMSOil in my WS6. Can anyone share the wealth of knowledge about the motor oil and what weight i should run?
Old 08-21-2008, 08:49 PM
mikenews's Avatar
Amsoil is great stuff!! I have been running it in everything I own for years...Harley, snowmobile,boat.....I would run 5w-30. With a good quality filter like napa. Also you can run it alot longer between oil changes than conventional motor oil. If I'm racing my car alot I change it every 5k. Every other car I own I go between 8-10k.
Old 08-21-2008, 09:06 PM
CETAWS6's Avatar
Ok cool thanks. I was running royal purple 10w30 and gotta do the oil change soon. I figure I give AMSOil a shot.
Old 08-22-2008, 05:22 PM
LT1Formula26's Avatar
is amsoil synthetic or not?
Old 08-22-2008, 09:51 PM
CETAWS6's Avatar
Yea it's full synthetic.
Old 08-23-2008, 01:43 AM
_JB_'s Avatar
I run it in my car, engine, tranny, and rear end.
Old 08-23-2008, 06:25 AM
flirtnwithdisaster's Avatar
Default oil
Not sure I would change from royal to amsoil. I did this in 2 vehicles a mustang and a new GMC with a 5.3. Both vehicles started using over a quart of oil at 3500 miles. Amsoil has a 12 month or 25,000 mile oil change interval, just change the filter every 12,000. I was adding1 qt at 3500 and another at 7000.. Another quart at or around 10,000 and the quart at the 12000 with the filter and so on. I was puting about 7 qts of oil in a year over the reg amount for a total of19 qts in a year. At 7.00 a qt that was 130.00. I should have stuck with the royal. Oh and they said it would increase my fuel mileage. I lost 2 miles per gal. I changed my oil every 6000 with the royal for a total of 24 qts. I felt better with the royal and had no early morning start uP noise. Has anyone else had this problem?
Old 09-14-2008, 12:07 PM
johnsoils's Avatar
I've been using AMSOIL for years, and switched my 1990 Silverado with a 5.7L over from Royal Purple to AMSOIL with no issues.
I've also ran Mobil 1 in the past years, and switched those vehicles over to AMSOIL with no consumption issues.
My 2003 Chevy Silverado has a 5.3L and I ran the AMSOIL 5W-30 for 19-months and 23,000-miles before the oil analysis report said it was time to change the oil. I never had to add any oil in the 23,000-miles, it was still running between the add and full mark at the oil change. I now have the new 0W-30 AMSOIL in the truck.
My wifes car is a 2003 Pontiac GrandPrix with a 3.8L. We ran her car 26,000-miles in 16-month before the oil sample report said the oil was getting low on TBN and it should be changed. I added a quart of oil every 8,000-miles which was less than conventional oil at a quart every 3,000-miles. Mobil 1 was a quart every 4 to 5,000-miles. The oil sample report also showed signs of a coolant leak. I pulled the intake and the gaskets were cracked. The $20.00 oil sample saved my wifes engine.
I have a large number of customers with the GM 3.8L engines and 3,000-miles on a quart of conventional oil seems to be the norm. With AMSOIL several are running like my wifes car, around 8,000 to 12,000-miles per quart. None of which are consumption issues.
Thanks, John
johnsoils.com
Last edited by johnsoils; 09-14-2008 at 12:12 PM. Reason: For got to put miles per quart of oil added.
