Does anybody have exploded parts view of the door 93 camaro
Can someone help me im looking for the exploded view with part numbers/descriptions for inside the doors on a 93 camaro
Ryan
Ryan
Location: Your girl's back door giving her the long stroke while you're at work
If this doesn't help, a dealership can pull up the diagram
1) Manual locks Manual locks Right2) Actuator Right3) Upper striker Back4) Spacer Spacer Back5) Washer Washer Back6) Lower Lower Back7) Spacer Spacer Back8) Washer Washer Back9) Anchor plate Back10) Standard Standard Right11) Filler Right12) Handle inside Right13) Lock cylinder Back14) Key Back15) W/o t-tops W/o t-tops Right16) Outer handle Outer handle Back17) Lock cylinder Lock cylinder Right18) Inner handle Inner handle Right19) Lock **** Lock **** Right20) Upper hinge Right21) Lower hinge Right22) Upper Upper Right23) Lower Lower Right24) Lower seal strip Back
