TCS button not funtioning
Old 08-25-2008, 08:20 PM
pgh_ws6's Avatar
Default TCS button not funtioning
On my 02 WS6 my TCS button will not turn Traction control off. Any clue on what it could be? Just the switch? if so does anyone have a part number. It does work sometimes but 90% of the time it does not. Any help would be great.
Old 08-25-2008, 08:42 PM
LS184's Avatar
did u check the tcs fuse?
Old 08-25-2008, 09:09 PM
pgh_ws6's Avatar
I have not yet. did not think it would be the fuse because it works sometimes. If the fuse blew would it leave TCS on or off. Mine is on and cant get it off.
Old 08-25-2008, 10:20 PM
samson_420's Avatar
That just sounds odd. I don't know.
I want to see someone else chime in on this one.
Old 08-26-2008, 02:01 AM
jmdale1984's Avatar
Mine just started this, too. But with mine, when I start the car, the TCS is off now for some reason, then it turns on when I hit the switch, but it won't turn back off.
Old 08-26-2008, 08:16 AM
pgh_ws6's Avatar
I have not pulled out the switch yet to see if something is wrong with it. Is it worth buying a new switch or If I pull the fuse will I also kill my ABS or another system?
Old 08-26-2008, 12:46 PM
MrEddie's Avatar
Mine has done this in the past when the battery is on its way out. The TCS will stay in "off" when first firing up. After starting again, the light is then out after the battery has a charge. I have a autozone duralast gold - one lasted 3.5 years, but the one I have now is a little over a year. When I first install the new battery, it will not do this at all.
Old 08-27-2008, 02:16 PM
99monguse's Avatar
My old 00 WS6 the switch was bad.
Old 08-27-2008, 04:21 PM
samson_420's Avatar
Post back when you find out what it was.
Old 08-28-2008, 02:06 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
If you need the switch, I have one
