door panel removal 1999 ws6
Old 09-02-2008, 07:25 PM
tigearl12's Avatar
Default door panel removal 1999 ws6
would like to know good way to take panel off without damaging panel or the clips in door and panel.changing monsoon speakers
Old 09-02-2008, 07:56 PM
LS6427's Avatar
You might break some, you might break none. You have no choice but to takwe the chance. Usually if you do break a couple you can re-arrange the existing ones and the panel will go back on 100% perfectly.
Old 09-02-2008, 10:19 PM
Danny2tek's Avatar
just remove all the bolts and pull UP and away.
Old 09-03-2008, 12:59 AM
98boxer's Avatar
theres no clips to our door panels, as said remove all the screws first and unplug the buttons and lift up
Old 12-09-2008, 11:33 AM
Glock23's Avatar
a little confusing ...
Old 12-09-2008, 11:55 AM
ndfrsd6's Avatar
its easy just take your time take all the screws out and pull it off
Old 12-09-2008, 05:19 PM
Formula413's Avatar
Two key things: Make sure you get ALL the screws (some are hidden, one under the handle, one in the storage pocket), and pull up first, then out. Check out this write up on replacing the window motor, it details how to remove the door panel.
http://shbox.com/page/windowmotor.html
Quick Reply: door panel removal 1999 ws6
