what is this bushing called?
It is a part of the tie rod end. If you car feels a bit loose, replace them.
They are only about 50 Bucks and will make a hell of a difference, but you will need an alignment after wards.
It is an outer tie rod, part of the steering.
There is no "bushing".
There is a lubricated metal ball and socket protected from dirt and water by a rubber boot.
1 Post
when mine had a hole or rip, i got a grease gun and filled it to the top with alot of grease then i used a special tape that sticks to itsself to seal it back up like new
Is there a lot of play in the steering wheel? Tie rod goes bad and there should be a lot of play back and forth without the wheel moving.
Cheap part and piece of mind fix.
Thanks for the replies guys.
There's a little bit of play on the steering wheel. I can wiggle the steering wheel back and forth about an 1/2 an inch and it won't do a thing before the wheels start turning. I'll replace both outer tie rod ends, and then get an alignment at a shop.
I've been reading up on steering system and I think i'll flush the fluid while I'm at it.
I also seem to be having a "popping" sound from my front right wheel when I make wide left turns. I'll do the ball joint test and see if I need to replace those as well. From what I've read, there seems to be a lot more work/tools involved with replacing those.
