Parking Brake removal
It is just a couple of bolts. Remove console. Remove bracket airbag module is on. Two 10 mm bolts on the floor bolt. 7 mm for the position switch. Rotate the wheel to get the lead cast cable end out of the parking brake cam. Squeeze the cable sheathe's ends to get it out of the p brake bracket.
