Do MSD wires need heat shields?
Old 09-09-2008, 05:44 PM
VetteMan's Avatar
Default Do MSD wires need heat shields?
Bought a set and the old shields don't fit the msd wires. My mechanic says the wires will burn up faster without them so he suggested I get some heat res socks to put over them. What do you guys think?
Old 09-09-2008, 05:48 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I have run RED MSD Wires for over 2 years without those shields and they are fine. I have LS1 and Edelbrock LTS...wires don't even come close to tubes.
Old 09-09-2008, 05:50 PM
VetteMan's Avatar
I have SLP hoker heads and each plug is between one. My current OEM wires burned out at 40k miles.
Old 09-09-2008, 06:10 PM
ae13291's Avatar
i have msd wires with my LT's and there fine, the tip of the msd wire bends the way u want it
Old 09-09-2008, 06:22 PM
SladeX's Avatar
oddly I manged to burn one of my MSD wires on the passenger side number 5 I think. Was bent out of the way AND my headers are ceramic coated...
I really wish I could put the shields on them. Oh well.
Old 09-09-2008, 06:34 PM
nemss1's Avatar
took she shields off when i got mine. no problems here
Old 09-09-2008, 06:37 PM
lastcall190's Avatar
Never ran 'em on mine, I just carefully bent the boots back when I ran 'em. I now have 7 LS1 GTO wires and 1 MSD
-J
Old 09-09-2008, 06:40 PM
SSNISTR's Avatar
I have the MSD's with heat wraps. But I have LT's and don't wanna take any chances.
Old 09-09-2008, 06:45 PM
VetteMan's Avatar
What heat wraps should I get?
Also, can't MSD take more heat than the OEM.
Old 09-09-2008, 06:46 PM
I used Taylor heat sleeves on my LT1 FWIW...
Old 09-10-2008, 04:43 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm not running any type of heat shielding on my MSDs
Old 09-10-2008, 05:07 PM
samson_420's Avatar
I dont have any shield on my MSD's. You can get the high temp boots though, they might prolong the life of the wires a bit.
Old 09-10-2008, 05:17 PM
99blancoSS's Avatar
No not needed.
Old 09-10-2008, 09:30 PM
79Jeep's Avatar
i agree, i have the msd's andhave no problem
Old 09-10-2008, 10:52 PM
CULATR's Avatar
my shields fit fine over my msd wires???? you are talking about the metal tubes with the spring at the end that connects to each of plugs right? my clicked on my plugs just fine? and im runing Lt's too........
Old 09-11-2008, 08:13 AM
VetteMan's Avatar
Yeah those are the ones I am talking about.
Old 09-11-2008, 09:23 AM
99blancoSS's Avatar
They will fit over the boot and you can use them. I have run them both ways, they dont make a difference.
Quick Reply: Do MSD wires need heat shields?
