A/C Clicking noise..voltage drop
Old 09-09-2008, 09:28 PM
killerinyou's Avatar
Default A/C Clicking noise..voltage drop
When I turn on my air conditioner about half a second later there is a click from the driver side of the engine bay and the voltage guage drops down pretty low. Then after the click the the voltage goes back up to normal.
Then when I turn the A/C off it does the same thing where there is a click and a voltage drop.
My A/C still blows strong and is cold but these voltage drops have caused the car to die.
Any advice would be helpful. Thanks.
Old 09-09-2008, 09:34 PM
blockheadnic's Avatar
this happened to my 98 right before the compressor locked up about a week ago. start the engine and turn on the a/c and listen under the hood and see if the compressor is making noise. if so its very good possibility its trashed.
mine worked for awhile until it grinded to a halt.
Old 09-09-2008, 09:57 PM
Once the A/C is running after the initial click and voltage drop, I don't notice any other clicks or grinding noises.
Old 09-10-2008, 09:42 AM
Well just for ***** and giggles, try to turn the compressors clutch not were the belt rides but the center of it, should be able to turn with little force.
if nothing wrong there i would check battery voltage, turn all acc on and load the bat, minus the a/c ie.... lights blinkers and watch volt gauge. does it crank slow.
Old 09-10-2008, 09:57 AM
Jon5212's Avatar
Sounds like you may have a bad clutch on the A/C compressor, could be an alternator on its way out, the voltage shouldn't drop a whole lot and should come back quick. My car stays about 13.5-13.7 volts and when I hit the A/C on it spikes for jsut a second and all is normal again.
Old 09-10-2008, 11:05 AM
samson_420's Avatar
How bad does the voltage drop when you turn the lights on?
The voltage should act about the same when the lights are turned on as when the AC is turned on.
It could be the clutch on the compressor, just sucking it down. But it could be a charging system issue also.
Old 09-10-2008, 12:25 PM
There is hardly any voltage change when I just turn the lights on. I went to autozone and they tested my battery and alternator and said everything was working correctly.
Old 09-10-2008, 12:28 PM
slow's Avatar
could be the high speed fan relays,
