Getting shocked by the Valve covers!
Hey all,
I was changing the oil in the Z and I just noticed that when the car is running, if I touch the valve covers I get a shock at steady short intervals. I'm thinking of checking out the plug wires, but do you guys have any suggestions of anything else I should be looking for? Is there a common ground for the ignition coils?
Thanks!
Thanks!
The high voltage is made in the coils so I suppose that could happen, yeah.If you could narrow it down to which one, you could take it off and look for cracks and carbon tracks from arching on the bottom or sides.
You might be able to unplug each coil one at a time(not pull the plug wire) untill the shocking stops?
you have a plug wire that is arcing. I bet if you turn the car on in the dark and look under the hood you will see it. Probably a cracked wire or one is not on securely. It takes about 5 mins to check them all....
lol... I should be able to look at the car again in the next couple of days.. It's been raining here... Rain always puts a damper on working on the car!
If it stays dry, I'll probably check for the visible sparks tonight...
Moderator
You may want to put voltmeter from block to chassis sheet
metal (like that ground terminal stud on the wheel well) and
see if the motor is at different potential. If so, look to the
ground braids (back of driver's head to firewall, maybe others).
The current loop ought to be so low a resistance that spark
can't bite you. There is a lot of electrical bumping goes on
and flyback from any cyclic inductive load could make the block
potential jump if it's not well strapped. That kind of thing can
really make block-referred sensors act freaky too.
