Stock Gauges
Stock Gauges
My Speedo doesn't work at all and neither does my fuel gauge(on full all the time). Could the Speedo be much more than just a cable? I know the fuel gauge is the sending unit, but what about the speedo. Also every now and then my volts meter drops a lil but if you hit or peck on it it comes back. i want to just put in a set of pod gauges (oil pressure, water temp, volts) My oil pressure will also rarely drop to zero when idling, but i know it has plenty of fresh oil. any helpful thoughts or suggestions would be great
Ground wire from/for which gauge? I hope to think that when i get time to install my new speedo cable that'll fix that problem...otherwise im gonna get the pods to fix other gauges
