maintenance for 1200 mile road trip!
Old 09-16-2008, 09:19 PM
TXZ28LS1's Avatar
Default maintenance for 1200 mile road trip!
so ill be making a 1200 mile road trip this saturday. im wondering if there is any maintenance things that i should do. the 02 Z28 has 49k on the clock now. i changed the oil at 47,xxx something.. i just got the tranny built, so i have a new filter/fluid, rear fluid was obvisouly changed when i got the gears, i just got the coolant flushed, and new fuel filter about 3 months ago. anything else? havent driven the car at all?
Old 09-16-2008, 09:49 PM
SOMbitch's Avatar
Should be good with an oil change when you get back. Remember to change the diff. fluid every 30k as per manuel.
Old 09-17-2008, 10:12 AM
ZexGX's Avatar
I'd change the oil before you go. Make sure the A/C works good and you have lots of money for gas... If you notice anything that is worn or will be worn in 1200 miles, fix it.
A good CD or two helps. Bring a code scanner if you have one...
