Recommend me a good Differential gasket?
Should i just get the same gm gasket or a better one? The original one didn't leak and i know some have problems with them leaking a tiny bit.
And im thinking all there is to it is lift the rear, block the front tires, and remove the differntial cap, does that sound about right? Any tips to a quicker and safter removal/install would be great.
If both surfaces are clean and free of old gasket material then the GM gasket will work just fine. I would hold a straight edge on the mating surface of the cover to make sure its not warped. I always use a wire wheel to clean the surface of the cover and a razor blade on the differential. Your method of attack sounds good....its a pretty easy thing to do.
I scraped mine with a razor blade on both sides. I also used a wire brush on the cover side.
Then I used plain ol' black silicone on the cover side(I real thin bead). The gasket that I used was the OEM paper type. No leaks since.
Just don't over tighten the bolts.
Thanks to all, i'll be doing this next weekend, just need to buy a gasket and looks like i'll be using gm one and small bead of black rtv as recommeneded by you guys thanks.
