What's wrong with my car?
Old 09-19-2008, 01:13 PM
DrewSG's Avatar
Default What's wrong with my car?
I was rolling out of driveway and it began shaking, the SES light was flashing too. I was going to drive it to autozone to have it scanned, but I was too scared to take it on the main road.
Old 09-19-2008, 01:57 PM
RsSean's Avatar
Missfire. Flashing SES light is not good. Have you done anything to the car latey? We need more information if possible.
Old 09-19-2008, 02:03 PM
DrewSG's Avatar
Nope. All car is all stock except Koni shocks
She has 80,000 miles and this just started happening a couple days ago.
DrewSG's Avatar
Misfire on cylinder 5, what steps do I take now?
Old 09-19-2008, 03:01 PM
question's Avatar
Check your plug wires for arcs/shorts, coil packs, etc. Maybe even pull the plug an see what it looks like.
Old 09-19-2008, 03:45 PM
DrewSG's Avatar
Do the plugs just pull on out? or do I need a special tool to take them out?
Sorry for the dumb questions, never done this before.
Old 09-19-2008, 03:47 PM
2002Z28Camaro's Avatar
just a spark plug socket and put anti seize on when you put it back in
Old 09-19-2008, 03:48 PM
question's Avatar
The spark plugs? You will need a spark plug socket and a ratchet to remove them. The wire should pull off with a little force on the boot, and you will probably want to replace all the plugs and wires while your down there. Check out www.installuniversity.com for some tips.
Old 09-19-2008, 03:49 PM
question's Avatar
Here you go buddy
http://www.installuniversity.com/ins...sity/index.htm
Edit* Link was supposed to take you right to it, but go to Install documents then down a bit and should see plug swap.
Old 09-19-2008, 04:17 PM
DrewSG's Avatar
Thanks for link and answers.
Just a quick question. Since I'm going to change the plugs, should I go ahead and change the wires too?
Old 09-19-2008, 05:15 PM
ZexGX's Avatar
Yep. Just be sure to route them correctly and protect them from heat/rubbing where necessary.
