water pump bolt broken off still in block.....
Old 09-20-2008, 09:04 AM
30th t/a's Avatar
Default water pump bolt broken off still in block.....
I have a bolt that snapped off while removing the water pump. There is about 3/16" of thread sticking out from the block. It wont budge with me using Plyers on it. Can I use a propane torch to heat up the block around the broken bolt to remove it?? I dont want to hurt anything inside the block.
thanks
Old 09-20-2008, 09:09 AM
Predator's Avatar
thanks
Did you try squirting it down with Liquid Wrench and then using the pliers?
Could you could drill a hole and use a screw extractor?
Old 09-20-2008, 01:37 PM
ae13291's Avatar
i would heat up the block around it and use some good craftsman channel locks and remove that thing. heating it up will make a very big differance
