VERY loud roar/grind/horrible sound from rear
Old 09-28-2008, 02:49 PM
SC_Camaro's Avatar
Default VERY loud roar/grind/horrible sound from rear
as tittle says the car (96 z28 w 130K) has a VERY loud roar when you let off the gas with the car in gear. i notice a deep vibration too but is not constant. i cant tell a whole lot about it but it seems to be coming from the rear passengers side. the rear end fluid and transmission fluid are at correct levels. it also pops/clanks in the rear when changing gears. when the gas pedal is pushed down the sound is much much much fainter and more of just a whine. its gotten really bad in the past two days and now is just unbarable. there cant bee too much back there i wouldnt think that could go bad especially being primarily on one side but i dont know much about rear ends.
Old 09-28-2008, 03:50 PM
Medic/Z28's Avatar
From what you're describing.... sounds like you broke some teeth off your gear diff. and your bearings went out. My bearings went out at 75,000 miles and I broke teeth of the gears at 170,000 miles. The bearings made the loud whiney noise and the clatter sound resulted in broken gears due to low diff fluid from a leak I never took care off. Hope this sheds some light as to what you might be dealing with.
Old 09-28-2008, 04:38 PM
UAZ28SS's Avatar
So it sounds like it makes more noise when NOT under load? Bet your bearings are toast.
Old 09-28-2008, 04:42 PM
*98TransAm*'s Avatar
start saving for either a 9 inch or a 12 bolt!
Old 09-28-2008, 07:56 PM
SparkyJJO's Avatar
Old 10-01-2008, 10:54 PM
mateols1ss's Avatar
Sounds like bearings to me. Mine went out at 75k as well.
Old 10-01-2008, 11:08 PM
TA1364's Avatar
I had something similar happen when pinion nut was loose. I also have a bad bearing right now, its just loud all the time under load or not.
Old 10-03-2008, 06:06 PM
jeffboy757's Avatar
yea pinion crush sleeve can be be off, but its most likely the bearings are toast. hurry and fix it before you destroy the entire rear end!
Old 10-04-2008, 05:36 PM
RacerXLs1's Avatar
I agree with him ^^^^^
