Trip Odometer Resets Itself
Old 09-29-2008, 01:39 PM
my bandit's Avatar
Default Trip Odometer Resets Itself
for some reason everytime i turn on my car now the trip odometer will reset itself. i really dont know why though. my car is a 99 trans am with 117500 miles on it.
also is the speedo supposed to go all the way to 155 when i turn on the car? this is the first time it has ever done this since i got it.
Old 09-29-2008, 01:59 PM
2001NBMZ28's Avatar
I was betting you had a '99 just by reading the title of your post - it's caused by low battery voltage. There's a TSB on it for the '99's to replace the instrument cluster, but a good battery will make it go away. TSB doesn't mention the gauges sweep but usually happens with the trip reset.
Old 09-29-2008, 03:04 PM
keliente's Avatar
Replace with a new battery. VERY common 1999 problem.
Old 09-29-2008, 10:13 PM
wade99z's Avatar
Ditto. Same problem last fall. Put in a new Optima, fixed. Make sure you get the higher amp rating recommended. The lower amp one is more or less for the V6.
Old 09-30-2008, 05:36 PM
Danny2tek's Avatar
Yep clean the battery terminal or change your battery... been there done that
Old 09-30-2008, 11:17 PM
4WOFURY's Avatar
I have a 99 too, and I had the gauge sweep not too long ago. It's fun really, just pretend that you accelerated that fast and pegged out.
My trip reset on me tonight too :-(. But I took the battery out lol.
Old 01-04-2010, 06:51 PM
COPO9560's Avatar
I recognize this is an old thread but same thing happened to me today - believe I have a good battery but it is about 5 degrees outside and that can cause drop in voltage.
My gas gauge got a mind of its own at the same time and goes way past full and is stuck there. Hoping when weather warms up this will also correct itself.
Anyone else in cold weather have same problem?
Old 01-07-2010, 01:48 AM
4WOFURY's Avatar
Damn, I didn't even remember posting that lol.. thought it was a post I posted like it not just a few days ago..
Old 01-07-2010, 09:45 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
Ok I just bought a new battery and I don't think I got a big enough one. It seems to still die easily. What size do you guys recommend?
Old 01-26-2010, 10:25 PM
SSmokin99's Avatar
I have this same problem!!
Old 01-27-2010, 12:45 PM
Blazingz28's Avatar
My 99z has been doing this for months now. The battery is fine, has NEVER died on me, but I guess I will replace the battery if that will fix it.. terminals are fine
Old 01-27-2010, 12:51 PM
BIG_MIKE2005's Avatar
My car has done this in the past & is currently doin it again with this cold spell we have been having. Its due to low voltage as stated already. If your running a cheaper brand & at either stock or lower rating its gonna happen. You need to buy a good battery like a Optima red top. I did a self test this last time & bought a cheapo WalMart battery to replace my cheapo O'Riellys battery. Both batteries lasted about a year & started doin this during winter.
I'm getting ready to get a Optima red top & stop messing with these cheaper lower amp batteries.
Old 01-27-2010, 02:54 PM
PowerShift408's Avatar
My 99 HOSS has been doing this. Saw that replacing the battery was the prescribed cure, so I went and got one even though my battery never caused any problems. Upon installing the new battery, I still witnessed the same problems in my car.
Old 01-27-2010, 04:19 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
RED TOP OPTIMA will fix it.
Old 01-27-2010, 05:50 PM
I will never run an Optima battery. Had one once, died within 3 months.
Old 01-27-2010, 08:19 PM
9silverbird8's Avatar
^^ Ditto. Tried to remedy this problem with $200 optima yellow tops. I killed them absolutely dead in no more than 5 days. After going through 4 yellow tops I said eff it and got an autozone duralast gold for $80, problem resolved. Optimas are crap.
Old 02-07-2010, 09:03 PM
That's MISTER MODERATOR
Paul Bell's Avatar
First, I'm very happy with my yellow top. It's at least five years old. It was in my van and lives on in the T/A.
Second, there was a TSB on the gauge/trip odometer issue. GM would swap out the entire gauge cluster to one with a different chip. The problem is worse when very cold, low battery voltage conditions or if the car sits for an extended period.
My car has this problem and I doubt GM will service it. I'm wondering if there's a fix we could do.
The TSB number is 990849009.
Old 02-08-2010, 08:30 AM
Paul Bell's Avatar
These people will fix it. GM dealers use them. $175.00 plus shipping, 48 hour turn around.
http://www.modelelectronics.com/index.asp
Old 02-08-2010, 10:22 AM
99monguse's Avatar
Will GM replace the cluster since theres a TSB? I doubt it. So...is this a problem with the battery or the cluster, has to one or the other.
Quick Reply: Trip Odometer Resets Itself
