Need Help! Headlight 99 TA wont go up or down
Hey Guys thought maybe someone could help me out cause im stumped.
My drivers Side Headlight wont go up or down. I replaced the Motor and put everything back together. Turned the headlights on and nothing....
so i took wire leads and hooked them directly to the batt to see if the motor was good and sure enough it was. So I then figured the Headlight control module was bad. so I took one off my friends ta that I knew worked and pluged it in and turned the headlights on and still nothing....
I checked both of the 15 amp fuses that supply power to the headlight control module and both of them were good. I checked all other fuses and all of them were good. I checked the wireing going from the headlight motor also and it looks fine.
I have no Idea whats going on and now im pretty much stumped? Can someone please help me out?
BTW the passengers side goes up and down just fine its only the drivers side that wont. and the drivers side used to work sometimes and other times it wouldnt before it quit working all together.
Thanks
Thanks
