Help with radiator fluid fluid purchase
Im doing my radiator flush in a couple of days and i dont know which brand to buy, Prestone is $13.99 at autozone for the 50/50 fluid mix......this stuff is expensive ...how many of these does everybody buy to fill up the radiator ???? the guy at autozone tells me to buy 4 which will be around $50...the same guy that tried to tell me not to put NGK TR55 plugs on my car because i'll have problems ......any suggestions on what kind to buy and how many containers
As far as the coolant goes, personally, for 10 1/2 years in my 1998 WS6 I use: South Florida weather like you have in Cali. Engine runs very cool.
Half jug of Dexcool
1 bottle water wetter
Distilled water (top it off with this)
1 Post
DExcool hater here! that stuff sucks *** and will corrode the cooling system in a non pressurized secondary system like on an f body. i have been using green coolant since i bought my car. (about more then a year now) and do not buy 50/50 mixed coolants already, buy the concentrated ones and mix it yourself and you can get 2 gallons from that. i also buy my coolants from walmart its cheaper
I can't remember if it was here or norcal-lsx but i read that dexcool was bad for the waterpump. As a byproduct of the coolant, a sort of milky-jelly like tan substance would appear inside the system. Usually by just removing the radiator cap you could see an sample of it. I read to just flush the system, use a full bottle of water wetter then top off with distilled water. Is this extremely wrong? Should I add dexcool?
Just cuase my car overheated today and I'm wondering if I fucked up.
I really hope that becuase I'm running without any coolant I wont see problems arise. My car is still overheating though. Still need to figure out why, just sucks that it happens in coincedence with me switching to just WW and Distilled Water.
I noticed a pool of coolant near the floor bed of the passenger side. Once I mentioned this to people, everyones suggestion was a bad heater core = Replacement. I've searched around.. looks like its a few hour job. Mechanics are charging me 400 part and labor. Is this worth it or is it something doable? I just cant have my car on downtime if I'm not able to finish.
