Belt squeek when cold
Old 10-06-2008, 12:09 PM
Black98T/A's Avatar
Default Belt squeek when cold
Just got my 98 WS6 last week. After startup mainly(only?)when the engine is cold the belt squeaks loud and gets louder under acceleration. The belt looks new with no defects, could it be the tension pulley?
Old 10-06-2008, 01:49 PM
99SSragtop's Avatar
get a new gator back belt, problem solved.
Old 10-06-2008, 04:16 PM
xRelapse13's Avatar
either that or regrease the tensioner pulley
Old 10-06-2008, 08:42 PM
Black98T/A's Avatar
thanks, I'll try both before I replace the pulley, any reason why it does only when cold?
Old 10-06-2008, 08:51 PM
SSNISTR's Avatar
Just BUY a new tensioner pulley. They squeak when the bearing is on it's way out. They are cheap and easy to change.
Old 10-06-2008, 09:51 PM
99SSragtop's Avatar
untill they warm up they can squeek as they get old.Gator back's are ridged and work well. The pully will have a bearing sound when they start going. They really don't squeek. To test the pully squirt some lube on the bearing part ( crawl under the car to do it ) and see if that is it. most ikely its the belt. Keep your old one in the trunk for " just in case "
Old 10-07-2008, 03:19 AM
ae13291's Avatar
get the gator and dont look back
Old 10-07-2008, 01:22 PM
TireSm0ke's Avatar
If the belt is not cracking, I wouldnt necessarily replace it. The squeak usually comes from the idler pulley or the tensioner pulley. They are both easy to replace, I actually replaced the tensioner assembly a few minutes ago. Theres a write-up for the idler pulley at installuniversity.com
Old 10-07-2008, 02:27 PM
99SSragtop's Avatar
the belts do get dry and therefore squeak.
Old 10-07-2008, 06:43 PM
Schnell's Avatar
Do some searches, someone on here did a great write up on re-greasing your tensioners.
Old 10-07-2008, 07:04 PM
Grimes's Avatar
That's good if the pulley is making sound, but if the tensioner has gone out, you just have to replace it.
Old 10-07-2008, 08:26 PM
SSNISTR's Avatar
Guys, when the pulley squeeks it's due to a bad bearing. Greesing it is only a cover up. If the bearing seizes you'll have a big mess on your hands. Don't cheap out, buy a new tensioner. As I said, they are cheap and easy to swap out.
Old 10-07-2008, 10:48 PM
99SSragtop's Avatar
That was my earlier point. If you spray it ( wheel bearing )and the noise goes away then the bearings are bad.
Old 10-08-2008, 02:54 PM
TheBlueKnight's Avatar
I just bought a 2000 WS.6 last month. Same thing with mine, When I started it up it would squeak until it warmed up (took about 20min of driving for it to stop squeakin). The belt looked brand new so I had no reason to suspect it. I decided to replace it anyway, went to kragen, bought the serpentine belt, threw it on in 5 min, stated the car, and no more squeak! Been a month and its as quiet as a mouse. Just tellin you my story, sure it could be other stuff but thats how it went for me.
Old 10-08-2008, 04:21 PM
99SSragtop's Avatar
Thank You.
Old 10-10-2008, 12:20 PM
Black98T/A's Avatar
Ok..so far I
1.replaced tensioner pulley with a new one from Autozone($17.99)-DID NOTHING....returned...put old one back in a little greased up.
2.replaced belt with a Goodyear Gatorback($25.99)-a little quieter but squeak is still there!
Haven't had the chance to drive the car yet...so I don't know if it drives quieter.
Is it possibly another pulley?
Old 10-10-2008, 04:47 PM
Schnell's Avatar
Exactly. Chances of the tensioner squeaking are lower then a pulley. Regrease. Pull all of the pulleys off and regrease them all. Don't listen to these people on hear about buying new unless you want to do that every 2 years.
I grease most of my non greasable fittings including lower ball joint. It's called a grease needle.
Old 10-26-2008, 07:01 PM
Black98T/A's Avatar
Update-I found the culpprit....it was the small ac pulley making all the squeeking...since my ac stopped blowing cold the day after I bought the car last month, and shouldn't really need it till atleast March... I removed the ac belt....quiet as a mouse now.
Old 11-10-2008, 05:33 PM
azslpss01's Avatar
Anyone know if you need to torque the tensioner pulley and if so what do I torque it down to.
Old 12-15-2008, 12:29 PM
JZ28's Avatar
I am having the same issue. Have replaced the tensioner and the idler pulley. I seriously think that the belt is squeaking on the water pump pulley. The surface of that thing is almost polished just due to normal contact with the belt. It does go away after a few minutes though. Now if I can just find a water pump!
Quick Reply: Belt squeek when cold
