My car wont idle at any less than 2k RPM's
Old 10-08-2008, 09:00 PM
jt76's Avatar
Default My car wont idle at any less than 2k RPM's
this started last night. My car will drive itself down the road, i dont have to touch the gas, i take it out of gear the RPM's wont settle down below 2k rpm's unless i let it sit for like 20-30 seconds. It almost acts like the Throttle is stuck open, but thats not the case i dont think. Anyone have any ideas on this?
Old 10-08-2008, 09:26 PM
samson_420's Avatar
Maybe a carbon fouled IAC. Or a vacuum leak.
Old 10-08-2008, 09:47 PM
LS184's Avatar
like said above.....bad iac
Old 10-08-2008, 10:03 PM
samson_420's Avatar
I know that's my answer and it sounds right. But, I have never seen a IAC go bad.
Old 10-08-2008, 10:08 PM
LS184's Avatar
u never no, they told me my fuel presseure regulator never goes bad an d it did hahaha.....it could also b a vacumn leak, did u swap out intakes or anything recentely? also have u looked at ur tb lines to make sure they werent sticking?
Old 10-13-2008, 02:58 AM
xephona's Avatar
I had the exact same problem when my formula overheated. It was throwing a code for a faulty cooling fan, and a throttle body positioning sensor, all due to a loose wire for the fan.
Does yours do it all the time? Or just after it is warmed up?
