pinging noise from under rear end area
Old 10-08-2008, 10:24 PM
DUhulk78's Avatar
Default pinging noise from under rear end area
I just cant figure this out. This sound has like a hollow ping to it, and it sounds like its coming from the rear end area. It happens when i first start to move from a stop, or like if i park at a slight incline, put it in park, and i hear it when the car rolls back when i take the brakes off, and it hits the park gear. I hear it really bad when i launch from a dig, like something might be flexing on the exhaust to make this ping sound. Maybe something with the torque arm??? Its just embarrassing when people hear it. Any help guys?
Old 10-09-2008, 12:48 AM
01CaMMMaro's Avatar
most likely the joint between your driveshaft and rear end... had the same thing happen on my old truck
Old 10-09-2008, 04:44 PM
DUhulk78's Avatar
Was it having the same symptoms?
Old 10-10-2008, 12:39 AM
01CaMMMaro's Avatar
exact same symptoms... in my truck i could get underneath the car and shook the driveshaft, it was loose so i knew that was the problem. pretty easy to do
Old 10-10-2008, 09:20 AM
01CaMMMaro's Avatar
mine would rattle when i hit bumps too but especially when i rolled forward/backward in park without the ebrake on... my truck was auto
Old 10-11-2008, 12:23 AM
silvermullet's Avatar
Do you have aftermarket exhaust? I have the exact same problem on mine, I swapped u-joints for nothing. My Borla exhaust has band style clamps and found that the exhaust flex makes that ting ting sound. I am thinking of replacing the trans/torque arm mounts to reduce the flexing.
Old 10-11-2008, 03:37 PM
01CaMMMaro's Avatar
could be your exhaust mount also, but that would be pinging would be pretty constant. im still thinking its your u-joints since you mentioned it did it especially when you put it in park and rolls to a stop.
Quick Reply: pinging noise from under rear end area
