Window motor replacement
Old 10-09-2008, 03:56 PM
pinesol_hater's Avatar
Default Window motor replacement
Ok, I've searched a lot of places and read the FAQ on window motor replacement but still have a question. On a 2000 trans am can you replace the motor without removing the whole regulator from the door? Some sites and how to's I've seen say I have to pull the whole reg and flat wound spring out and others make it just seem like I have to drill out 3 rivets and swap the motor only. I just want to know what I'm getting into before I tear my door apart. Am I better off to spend the 100 bucks to get someone to do it????
Thanks!
Old 10-09-2008, 04:11 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You can just drill out the rivets. I replaced one on my 02 TA and both on my 94 Z28, which took 30 minutes total
Old 10-09-2008, 04:44 PM
01CaMMMaro's Avatar
new one is $50 i think at o'reilly with the core.
Old 10-09-2008, 07:51 PM
SparkyJJO's Avatar
For your sanity do NOT remove the whole mechanism from the door. Super PITA and easy to mess something up (I bent something slightly somewhere because it doesn't operate completely smoothly anymore ). Drill the rivets out. Just be sure to support the window glass while doing it.
Old 10-09-2008, 08:01 PM
Danny2tek's Avatar
Yep I drilled out the rivets, first time it will take a little time.
Old 10-09-2008, 08:13 PM
_JB_'s Avatar
Drill the rivets.
Old 10-09-2008, 08:57 PM
noriceinside's Avatar
i used this the first time i did it. now ive done each window motor on the past 4 fbodies ive owned. like others say, 30 minutes both sides. cake.
http://shbox.com/page/windowmotor.html
Old 10-10-2008, 11:34 AM
slt200mph's Avatar
These are great instructions and it will not take long to do it..30-45 minutes...I got mine at advance auto parts for $36 with a life time warranty...nothing to it...that sucker is a fast mover too compared to the factory motor...
Old 10-10-2008, 12:54 PM
lincolnmkv's Avatar
Drilling through the panel is easy. Drilling through the rivets is easy if you use a big enough bit. Use the link posted above and you will be fine.
Old 10-10-2008, 04:21 PM
Thanks all, I went ahead and did it on everyones recommendation and it was much easier than I anticipated, just like you all said. Took just over an hr and for my first time I was quite pleased. Thanks again!!
Old 10-10-2008, 04:26 PM
slt200mph's Avatar
You will be able to do the other one in 30 minutes now that you have done one already....it is not a matter of if ... it is a matter of when the other one will crap out on you.
Quick Reply: Window motor replacement
