Seafoam problem
Old 10-10-2008, 02:13 AM
Daniel92's Avatar
Default Seafoam problem
I have a 98 z28 with 155,000 miles. I used seafoam in the gas tank and in the oil crankcase. There was a big improvment with my gas mileage. Then I used seafoam in the vacuum hose. The hp went way down and so did the gas mileage. There is also some throttle hesitation at low rpm. Does anyone have suggestions?
Old 10-10-2008, 02:17 AM
TireSm0ke's Avatar
The brake booster vacuum hose? Just drive the hell out of it but its possible you maybe have fouled your plugs. Have you done plugs/wires before? With that kind of mileage that would be the first thing I do
SpaZMaN's Avatar
Are you SURE it was the vaccum line off the brake booster? Did you check the plugs to see if they were foul? What about fuel filter? Maby the seafoam knocked some crap loose and your filter is clogged.
Old 10-10-2008, 02:29 AM
Craiggg's Avatar
Yeah should run the gas as low as you can. Then change fuel filter. Also change your oil after 100 miles or so if you haven't.
Old 10-10-2008, 03:15 AM
Daniel92's Avatar
Could I have messed up any sensors? Also, do fouled plugs effect gas mileage?
Old 10-10-2008, 03:28 AM
Benner's Avatar
I wouldn't think so on the sensors. The problem that can arise with Seafoam on high mileage engines is that it can clean too much. Basically it can remove enough debris off of stuff that it can uncover problems that were already there. For example, in college my professor was telling me about a customer at the dealership he worked at, used the stuff on his Impala with something like 175,000 on it. Basically it removed alot of debris off the rings around the pistons and pretty much unclogged it so he was getting alot of blow by.
I've also heard debates that it can eat seals and rings on high mileage vehicles but not sure if I completely buy this one yet.
Either way Good luck with it.
Old 10-10-2008, 04:27 AM
Daniel92's Avatar
The engine sounds healthier and the car is smoother, it's just down on power and gas mileage.
Old 10-10-2008, 11:20 AM
xXSilencerXx's Avatar
Change your plugs. Did you get any codes at all from doing it? I had a multiple misfires the first time I did it.
Old 10-10-2008, 11:02 PM
Daniel92's Avatar
No codes, Im going to change my spark plugs and fuel filter.
Old 10-10-2008, 11:08 PM
texasglock23's Avatar
Post up after that. Plugs, oil, and fuel filter is always a good idea after Seafoam.
Old 10-11-2008, 12:50 AM
Tech Resident
ChocoTaco369's Avatar
A couple things:
1.) First and foremost, are you throwing any codes? Even if your SES light isn't on, you may still have thrown a code. Get your computer scanned and check for any problems. If you get a code, tell us what it is. If you're clean, continue on.
2.) Make sure you properly connected the vacuum hose. A vacuum leak will give you exactly the problems that you are having.
3.) Check your plugs. In rare occurrences, Seafoam can cause a bad plug. Seafoam doesn't damage spark plugs per say, but what can happen is, since your engine is producing so much heavy carbon smoke, if a plug was on its way out, it could push it over the edge. Basically, it's the straw that broke the camel's back. Seafoam won't damage a plug that wasn't about to die anyway.
4.) Check your O2 sensors. The same thing can hold true for O2's as for spark plugs. If your O2's were old, the heavy carbon smoke could have pushed a dying O2 over the edge. A bad O2 would cause EXACTLY the problems that you are having. I'd be more inclined to think it's an O2 sensor than a plug because a bad plug usually causes a flashing SES light and a rough running engine. A bad O2 could just cause heavy fuel usage and robbed horsepower while the engine seems to be running fine.
5.) ONCE - and this is HIGHLY unlikely - but ONCE I heard of someone damaging a catalytic converter by using Seafoam. Don't ask me how it happened. Don't ask me if this is actually true. I just "heard" it. It's possible a cat could have gotten clogged. That would cause horsepower and fuel economy problems. Of course, it's also possible that I'll get hit by a meteor walking down the street tomorrow. However, if you've exhausted every other option, this is the last place I'd check.
Good luck!
Old 10-11-2008, 02:03 PM
Daniel92's Avatar
I changed my spark plugs about two weeks before seafoam. I will go through the possible solutions.
Old 10-11-2008, 02:36 PM
sweetbmxrider's Avatar
go to advanced, they do it for free. if the o2's are throwing codes, it will come up. you could go to a shop or something and pay $50-$100 i bet.
Old 10-12-2008, 04:40 PM
ghardester's Avatar
Yeah, the order in which a Seafoam/tune up is done is often missed. Do it in the gas and then change the fuel filter because all the crap in your gas tank has now been picked up and sent forward.
Do it in the oil and then change oil and filter.
If you do it in the top end you are sending all that engine build up to the plugs to be burned and then past the O2 sensors.
Changing the plugs BEFORE a treatment is self-defeating.
Old 10-13-2008, 02:18 AM
Daniel92's Avatar
I did a computer scan, codes come up for one o2 sensor and the maf. I replaced both o2 sensors and cleaned the maf. I paid $315 total. And it still runs bad. Something is definitly wrong with it. I'm going to change the fuel filter and the spark plugs, and see if that works.
Old 10-13-2008, 12:31 PM
96blackta's Avatar
Moral of the story? Don't run **** through vacuum lines. I don't care how many of you guys have done it on here, lol.
Old 10-13-2008, 03:20 PM
Or so I was always taught...
Old 10-13-2008, 10:04 PM
ae13291's Avatar
man did u dump the whole can or something? or u can seam foam it again
two negatives = a positive
Old 10-14-2008, 12:33 PM
79Jeep's Avatar
yea let us know how the plugs look when you pull them
Old 10-14-2008, 09:42 PM
fuseone's Avatar
ok which codes were they not just for what part it was but what were the codes. and you shouldnt just throw parts at a problem and hope it goes away.
Quick Reply: Seafoam problem
