So I dynod tonight (1st) and only made 8 HP more open cutout
I have the cutout in the 4" section before the stock catback. I made 345 HP/ 352 TQ closed and 353 HP/ 359 TQ open. This was on a Mustang Dyno so I didn't get the gain some people see (was told 20/20). Does this mean my setup is doing pretty good as-is? Now I need to see what I can get at the track with it.
Perfect example:
My 3755# A4 car made 344rwhp/314rwtq on a Mustang Dyno, yet runs 11's with ease (best of 11.67@115, 11.80's@113 in the heat). I have 275/50 drag radials, but ZERO suspension work done, aside from a Spohn adj. panhard bar, which does nothing for traction, and a set of older non-adjustable SLP boxed stock lower control arms, which also do nothing for traction.
I did just install a cutout (and 410's to replace the 342's), just to see what, if any, changes it makes at the strip.
Since open exhaust means leaner a/f ratio at WOT, I intend to richen up wot using my HPTuners.
I dynoed on a dynojet a couple of years ago with current mods minus the ported TB, I dynoed 328hp/341tq cutout closed and 339.5hp/353tq cutout opened. No Headers just Bassani ORY w/ cutout. Mid 12's was w/ a 1.89 60', before clutch started slipping. Clutch works fine on the street but before I head back to the track will need to upgrade to a LS7 clutch and Flywheel.
Wish I knew how much to add for the Dynojet conversion. I think Fran said 6% so that would mean 375 HP in my case but someone with more knowledge may know. My helmet is on the way and I have plans for next Wed to race since temps will be high 30's. Should run damn good then!
