the perfect LS6 intake rib shave!
1 Post
i remember somebody had once done it to match with the 98-00 coolant lines but i cant seem to find that pic anymore. does anybody have it?? im looking for the pic that somebody had dremaled the thing perfect all the way across and not shaving off any excess ribs. thanks for helping
You do this to clear the ls1 coolant lines. You can buy the ls6 lines. Just get a hammer and a chisel for the ribs. I was able to hit them pretty hard without causing any problems. I ended up just clearing all the ribs off the bottom.
You can also use a 1 1/2" air buffer......just do one rib at a time and you can make it look like it came from the factory like that, Also another thing i did was take the clips and all the black shielding off the tubes, then very carefully hammered them to almost a oval shape...you might want to take them off for that though.
1 Post
i will get up pics, it came out perfect! i marked them with a marker then i used a old pushrod to hit the fines off, then i cleaned it off better with a screw driver
