Mr Gasket Thermostat?
I just noticed looking through my summit racing catalog that Mr. Gasket makes an LS1 thermostat that is a 160 degree and it is like $12 and change... that's frikin cheap. has anyone else tried these.. really $60 for a SLP part is crazy.
Thanks in advance!
Thanks in advance!
[QUOTE=Y2K WS6;10352353]GN? umm this is going into an LS1..... Love your avatar by the way.
maybe the goose neck is the reason it's so much cheaper?[/QUOTE
Thanks!
Maybe I didn't say it very clearly? The actual t-stat part is mounted inside a curved aluminum "gooseneck" that the radiator hose connects to on the PS block. GN is held on by 3 10mm bolts IIRC. GN and t-stat are USUALLY sold as one unit but the t-stat part can be pulled out of the GN and replaced, but I have never done it. I just bought a $31 AZ GN & t-stat together and just replaced it as one unit. It was more expensive than Mr.G because it HAS the GN + t-stat and Mr. G is only the t-stat part that goes inside (minus the the GN). The GN is basically the housing that the t-stat fits INSIDE. Both together cost more than just the t-stat part but most vendors only sell the complete GN & t-stat as a unit.
Damn I wish I could talk I can picture it just not explain it
Thanks!
sorry i missread GN as "grand national" my bad on the nomenclature.
http://store.summitracing.com/partde...w=32&N=700+115
there is a link? so i'm guessing the themrostat is Inseperable from the goose neck?
Thanks
Thanks
Thanks
Thanks
For $31 AZ has the t-stat+GN unit together in 160*, 170*IIRC and 185*. I swapped in a 160* this summer with no probs so far.
