water pump leak
water pump leak
2000 Trans Am. Its leaking coolant. Followed it up to the water pump but the start of the leak is coming from like behind the upper driver's side portion of the pump by those two bolts, starting behind/underneath that lower bolt.
Where is the weep hole on these things? I'm trying to figure out if its leaking out of the weep hole, which would mean my pump is on its way out.
