how to remove the spring from the left of the TB
Old 09-15-2003, 09:06 PM
Tapout's Avatar
Default how to remove the spring from the left of the TB
anyone know how to remove the spring from the left side of the TB? TIA I need it removed for powder coating
Old 09-15-2003, 09:45 PM
theblur98ss's Avatar
Default Re: how to remove the spring from the left of the TB
I think if you take the two screws out that hold the blade onto the shaft the whole assembly slides apart.
Old 09-15-2003, 09:49 PM
Tapout's Avatar
I took the blade out, but it doesn't want to come out. Should I tap it easily with a hammer?
Thanks
Old 09-15-2003, 11:19 PM
Cheatin' Chad's Avatar
ttt
Old 09-16-2003, 08:23 AM
Old SStroker's Avatar
Thanks
The shaft is secured with a cupped spring retaining ring that pushes over the shaft on the end opposite the cam and spring. If you remove the shaft with a SFH, you really should put on a new retaining ring, but many folks don't.
Look closely at the ring before your remove the shaft. Don't reinstall it backwards.
Old 09-16-2003, 02:07 PM
Tapout's Avatar
great thanks!!
