Benefits from removing AIR and EGR???
Old 09-15-2003, 11:55 PM
99Z28RS's Avatar
Default Benefits from removing AIR and EGR???
What all is needed to remove AIR and EGR and whats gained by doing this?
Old 09-16-2003, 01:47 AM
blk~2000~Z28's Avatar
Default Re: Benefits from removing AIR and EGR???
ls1camaro.net
This website is about all you will need to talk you through the process. The EGR! will remove the obstruction in the intake. The EGR! is also said to affect fuel consumption and in some cases cause pinging. The AIR! will rid your car of the annoying noise on start up. The AIR! will also affect the longevity of cats if you still have them. They both will help to reduce nose weight, and the jury is still out on the AIR!, but I can say 100% that the EGR! will set an SES light. I've been living with the SES light for some time now, still waiting to have the codes permanently deleted.
Old 09-16-2003, 03:44 PM
Y2kPewterSS's Avatar
im fixing to remove the cats on my car. other than the annoying ses light, you got any other problems
Old 09-16-2003, 04:38 PM
PongoX11's Avatar
My EGR & AIR Fell off about 6 months ago, other then a damn SES light car runs fine
Old 09-17-2003, 07:58 AM
93LS1RX7's Avatar
HAHAHAHA He said the "Fell" off!!
Old 09-17-2003, 08:09 AM
Durien's Avatar
i dont have either of those things... dont need them!
the EGR just takes up space in the intake so i pulled it out when i got the ls6 intake and the air tubes & pump are useless since i got no cats!
the EGR has to be about 3-5lbs and the air tubes, Pump&Bracket about 7-10lbs.. so its a nice weight reduction mod
Old 09-17-2003, 09:09 AM
Jorday's Avatar
LOL! Your EGR and air pump did that, too? I took all that stuff of my car for heads and cam and just never put it back on. The best thing about not having it is that there isn't all that junk to look at under the hood. Take that crap off and then get a set of non-emission headers and it looks much nicer under the hood.
Old 09-17-2003, 10:37 AM
soundengineer's Avatar
hmmm...no egr = no exhaust going back into the intake = no carbon build up going back into the intake.
no air = no more stupid popping noise from the exhaust when the car is cold = people dont look at you like you're a dumbass
weight reduction from both
alot easier to work on the engine with all that crap out of the way.
Old 09-17-2003, 10:48 AM
NiceTry's Avatar
[/quote]weight reduction from both
[/quote]
yeah that's another thing, it is soooo much easier to get around under the hood without all that emissions stuff.
Old 09-17-2003, 11:32 AM
ss rally red's Avatar
I removed the AIR on my 02 a couple a hundred miles ago, no SES as of yet.
Old 09-17-2003, 03:34 PM
99TranTrany's Avatar
Another great thing is that you wont have to cut the backs of the FRC's if you decided to get them.There will be no AIR tubes to get in the way. And your spark plugs will be alot eiser to change.
AS soon as I removed my AIR system it threw a SES light. And we all know the EGR does too but o well there just codes the car runs fine.
Old 09-17-2003, 04:22 PM
Smoke_Ford's Avatar
Have those codes tuned out. Then you can pass emissions.
Old 09-17-2003, 04:28 PM
STF veteran / 10 second club
x phantom x's Avatar
You can pass emissions without the ERG and AIR??
I failed NYS emissions WITH them ... and before the cam.
The headers move the cats back further, which I believe makes them less efficient since they don't heat up as much.
Old 09-17-2003, 09:16 PM
INMY01TA's Avatar
I passed emissions in Md. with no cats, airpump, or airpipes.
Old 09-17-2003, 09:31 PM
As far as OBDII in Ga goes, you can remove wahtever you want AS long as it doesn't set a code. No visual inspection on emission equipment at all. Sims and edit can take care of that
Old 09-17-2003, 11:25 PM
99Z28RS's Avatar
So if i get LT's and delete cats (which i am) then i should go ahead and do it? and Edit will take care of codes?
Old 09-18-2003, 08:29 AM
LS1TECH Sponsor
foff667's Avatar
how exactly could removing your egr make your car ping? I never understand that it recirculates hot exhaust gasses back into your intake...how exactly does this cool down the intake charge enough to help stop pinging? lol it just sounds dumb to me maybe im wrong.
Thanks
Bill
Old 09-18-2003, 10:48 PM
99Z28RS's Avatar
ttt
Old 09-18-2003, 11:34 PM
The EGR's job is to add unused gases back into the intake, the PCM is calibrated to run with that gas. Taking that gas out of the equation "could" result in lean mixtures and thus cause it to ping. This is only my opinion though
Old 09-21-2003, 06:26 PM
lsx24's Avatar
If you get tuning after doing this (Which is the best option imo), will I pass visual in California? I know I can pass sniffer, but will they even know what to look for if I have no EGR and no AIR?
Quick Reply: Benefits from removing AIR and EGR???
