1998 LS1 misfire
1998 LS1 misfire
Ok so I just bough a 1998 Formula Ls1 with a misfire to the engine. It has race Pacesetter hearders on it andonly misfires every so often. There is no EGR valve and there is a washer over the spot it was at. Another thing is after the SLP hood there is no screen in front of the MAF sensor. Does it just need to be tuned?
Any ideas?
Thanks in advanced
Any ideas?
Thanks in advanced
does it sound like it has a large cam in it? I had a fuse blow (which ended up being a shorted injector circuit wire on the drivers side injectors) But you could start there, plugs, plugwires, ect.
Ok Ill try to replace those after I get some money comin in, All the fuse are all good, I didnt check under those silver covered ones. Do they have fuses as well or just like mini circuit boards? Dont know, that was prolly a stupid question
I'll check it out
I'll check it out
