HEADER INSTALL
HEADER INSTALL
What gasket is everyone using when installing long tubes? Also is it worth changing the 02 sensors while putting them on? Are the Bosch ones ok?
Re: HEADER INSTALL
I have SLP lt headers and they came with gaskets, and I don't know what brand, so I can't help you there. As for the O2 sensors, I wouldn't change them. From what I've heard, the stock sensors are Bosch and you'd be wasting your money if you replace them before they fail.
Hope that helps,
Jim
Hope that helps,
Jim
Re: HEADER INSTALL
was going to replace them b/c auto zone said it was why I keep getting an ses light now and then that says I am running lean in both banks
Re: HEADER INSTALL
I have found that the stock LS1 GM manifold gaskets work the best and are the most durable for use with headers.
As for the O2 sensors...... the sensors have recommended replacement intervals of 100,000 miles. Now, this is assuming everything is running properly and has not damaged a sensor. Additionally, this does not mean that the sensor is especially junk at 100,000 miles either.
All four of the sensors are the same except for the length of the wires. You can swap them around and see if the codes change. You may need some extension harnesses to do this. You can buy the extension harnesses from PPC.
Gordon
www.provenperformanceconcepts.
Gordon
Re: HEADER INSTALL
Anyway....
Re: HEADER INSTALL
Kevin I never had an exhaust leak, yet anyway. unless you count the cutout I had the code check 4 times and the last time they said it was 02 prob. Not sure about the knoledge of the Auto Zone employees?
