whats the diff. between these 2 magnaflow mufflers
No i dont think it will work. It has the inlet on one side and the outlets on the other side. F-bodys have an inlet and an outlet on one side and an outlet on the other side. I dont recommend it, would take to much work to get it to work and the flow wouldnt be very good.
(12288)
This cant be used like the muffler above. As you will be able to see that from the internal design.
Hope this helps you better understand.
(12267)Here this is the difference between the 2 number you are asking about. This muffler can only be transverse mounted the inlet is on the top right and the exits are on the bottom right and left.
(12288)
(12288)
(12288)
(12288)
