TR Poly motor mounts
Old 09-20-2003, 11:24 AM
Viper's Avatar
Default TR Poly motor mounts
WOW, huge difference in the car.
First off, thanks to Fulton-1 for suggesting TR's motor mounts so many times. Thanks to Humanoid; they were a piece of cake to install.
No more y-pipe banging - 100% gone!
The car actually became much more civilized ( I have H/C , LT headers with no cats, 3-1/2" exhaust all the way ) and easier to drive.
Still feel the lump of the H/C, but it's now in the actual body instead of inside the cabin.
I recommend this mod to everyone who's even thought of it - you will not regret it. I'm glad I did both instead of just one side.
Old 09-20-2003, 11:57 AM
theblur98ss's Avatar
Default Re: TR Poly motor mounts
I agree. I've seen some car with the stock mounts and I'm waiting for the motor to fly out. It's a must do mod once you start making alot of power.
Old 09-20-2003, 04:46 PM
WILWAXU's Avatar
hehe.. just installed mine today
Old 09-20-2003, 05:20 PM
2001CamaroGuy's Avatar
had mine for about 6 months....couldn't imagine having a H/C car without them....
Old 09-20-2003, 06:47 PM
SuperSport2000's Avatar
Where can I get these motor mounts? How much? Material
-Jasen
Old 09-20-2003, 06:54 PM
Viper's Avatar
Thunder Racing - sponsor on the right. $50? Polyurethane. Made to be a direct fit; Energy Suspension makes them too but you have to do some modifications to make it work.
Old 09-20-2003, 07:22 PM
SmaknaSS's Avatar
Cool. I think I'll order some.
Old 09-21-2003, 12:52 PM
Visceral's Avatar
Whats the install like? I just put the motor in, so my timing SUCKS, but they sure seem like a nice mod to make the car shake around less, and Im make "alright power"
How long was the install and what was the basic process?
chris
Old 09-21-2003, 01:19 PM
quickWS6's Avatar
Go for solid mounts, no KR, no additional vibration that I noticed, more room, and about 10 lbs off the nose.
Old 09-21-2003, 04:35 PM
WILWAXU's Avatar
Install is straightforward. I was doing a K member at the same time, so it was even easier
Basically you drill/cut the steal rivets out of the stock mount "clam shell" and replace the rubber stock mounts with poly units and bolt the clamshell back together. I used the Prothane kit. Everything was included. Directions were clear and precise.
Old 09-22-2003, 03:04 PM
Great thanks guys
Old 09-22-2003, 03:32 PM
Humanoid's Avatar
I have only done the one side so far. It is a huge diff when it comes to stopping the motor from moving. My motor moved 1 1/4"+ now I have less than 1/2" clearance with my y pipe and no banging.
Old 09-22-2003, 03:59 PM
Benjamin Russick's Avatar
What did you guys use to move the engine? Floor jack and a block of wood? I'm assuming you have to move the engine up to get the old mounts out and new in. Could this be done in a garage on ramps? Thanks!
