power steering reservoir leaking, how to fix?
Soo my power steering started leaking, it only leaks when the engine is on and you turn the wheels back and forth. Its neither the high pressure line or the return line, which leaves it to be either the whole pump assembly or the power steering reservoir. Im hoping it is just the reservoir. It either started leaking after I took it off road(doing donuts/ rock crawling) or after it froze for the first time here. The power steering works fine still, its just leaking
Does anyone know how to get the power steering reservoir off?
