Whats the biggest TB I can fit on an LS6 intake?
Old 11-18-2008, 10:35 AM
bonestockz06's Avatar
Default Whats the biggest TB I can fit on an LS6 intake?
As title says, what is the biggest size even if it has to be ported or modified in any way.
Old 11-18-2008, 12:34 PM
teke184's Avatar
i thnk the mouth on the ls6 is 78mm...either that or 75mm.
i'm sure you could fit an 80mm TB on it and port out the intake mouth.
not sure its worth much though
Old 11-18-2008, 06:16 PM
Red99TA's Avatar
Technically you can put a 90mm TB on there but you have to send the intake off to TPIS for them to modify the opening.
Old 11-18-2008, 10:43 PM
Are you serious? A 90mm will fit? I didn't even think you had enough room to modify an ls6 opening to 90mm. That should be a serious improvement over the stock TB.
Old 11-19-2008, 01:15 AM
F8L_LS1's Avatar
by modify... they mean cut off the front and put a new opening to fit a 90. i think it costs around 300 for them to do it.
im considering having it done myself.
Old 11-19-2008, 01:18 AM
hashtagBMW
Speed Density's Avatar
Or sell your LS6 w/ TB for $300 and take your 90mm TB you sound like you already have and put it on a FAST for an extra $500
Putting an 90mm TB on an LS6 probly wouldnt result in any power gains.
Old 11-19-2008, 07:52 AM
teke184's Avatar
TPIS reports similar gains to the FAST
4 pages in i think
its $350, then you need the 90mm TB
Old 11-19-2008, 09:31 AM
Restricted User
socmguy's Avatar
not worth the time or money to put a 90mm on an LS6. Go big or go home.
Old 11-19-2008, 05:17 PM
You're right, I just went through their dyno sheets and the entire article on the 90mm intakes with tb's and totally not worth the money. I'll just save another couple of bucks and go FAST...
Old 11-19-2008, 06:05 PM
F8L_LS1's Avatar
well... might as well go fast anyway. i wonder if the tpis molded tb intake would fall to pieces if it had any kind of FI ???
too much pressure!?
Old 11-19-2008, 11:08 PM
SOMbitch's Avatar
[QUOTE=F8L_LS1;10512178]well... might as well go fast anyway. i wonder if the tpis molded tb intake would fall to pieces if it had any kind of FI ???
too much pressure!?[/QUOTE
If you are talking F/I from a T/C or S/C a fast will only show marginal gains on a LS6 and at higher boost pressures is not as reliable due to the 3 piece design. The burst panels are recomended for the FAST in these applications.
Not to many boosted guys on a FAST for a reason.
