motor mount bolts
Old 12-14-2008, 04:02 PM
philsblwnz28's Avatar
Default motor mount bolts
I need some pics of someones motor mount bolted to the block. I cant remember what bolts go where. There are some bolts with studs. Please help asap....Want to get motor in...LOL
Old 12-14-2008, 04:29 PM
firehawk#682's Avatar
ok i think this is the driver side of engine from the bottom.
here is another one but i don't remember where is was from it looks upside down tho.
Here is one from the bottom front of the passenger side
Same side but this one is turn on its side
i hope this helps a little bit
Old 12-14-2008, 04:40 PM
All Black SS's Avatar
drivers side top needs studs if you put the heat shield back on. If not none of them need studs. I might cut them off when I do my mounts.
Old 12-14-2008, 05:14 PM
Damn, worked perfect. Thank you guys.....Got it done.....
