LS6 intake question
Old 12-15-2008, 09:34 AM
wmcfa's Avatar
Default LS6 intake question
What is the largest throttle body the LS6 intake can hold. Can it hold an 85 mm?
Old 12-15-2008, 02:42 PM
SOMbitch's Avatar
Unless you get the snout changed by TPIS it is the stock 75mm. Just get it ported by sponsor.
Old 12-15-2008, 10:23 PM
CriminiSS's Avatar
you can put a 85mm TB on an ls6 intake. I have one for sale if your interested.
Old 12-16-2008, 10:19 AM
wmcfa's Avatar
how much?
Old 12-16-2008, 10:50 AM
teke184's Avatar
you can put a larger tb on, but the mouth of the intake is still only 75mm or so.
so that added size is pointless.
kindda like putting a 3" inlet muffler on, but a 2.5" outlet
Old 12-16-2008, 04:44 PM
DoubleTapDrew's Avatar
I measured the mouth on the LS6 intake and it's 75mm, so that seems like a recipe for turbulence unless you port the LS6 inlet
Old 12-16-2008, 04:47 PM
Mean87SS's Avatar
Just port the stocker...
Old 12-16-2008, 09:07 PM
SOMbitch's Avatar
I was thinkin the bolt pattern was different but had a brain fart and was thinkin 90mm like my FAST TB
Old 12-16-2008, 09:45 PM
SSTYCOON's Avatar
shaner S3
Old 12-16-2008, 10:34 PM
LS1-450's Avatar
It's not pointless. Using an 85mm in front of a 75mm opening shortens the length of the 75mm restriction. This reduces the pressure drop through the area. Further, it acts as a funnel into the intake, gradually increasing air speed from the filter to the runner.
wmcfa,
Most 85mm TB's are sold w/ adapters & easily connect to the LS6 manifold. Summit sells a good kit @ a good price, if the offer made in this thread doesn't work out for ya. Good-luck
Old 12-29-2008, 04:33 PM
CriminiSS's Avatar
LS1-450 is right. A larger TB also increases throttle response. Pming the OP.
