e cut out wiring installation
planing on getting a 3" Qtp e cut out. i was just wondering from all you cut out guys, how would i be able to run wiring into the interior.. let me know thanks..
Banned Village Idiot
i dont' know where you are going to put the e cut out but i have mine in the "I" pipe and its right under the back seat pass. side... under that seat theres a small cover i removed that and ran the wire under the seat and under the carpet to the middle of my car... it was pretty easy no drill holes needed
Remove the passenger side rear seat bottom cushion (1 bolt). You'll see a plug you can slice and pull the wires through. You're having it welded under the rear seat cavity, right?
I originally came up through the area under the seat and midway through my first track rental I noticed I was missing insulation around the wiring. The dump exit was a little too close to the wiring entry in to the vehicle. I removed that section of wiring and ran it through the rear passenger floor board location. I know a few folks that have had the same issue. What ever location you use just keep the wiring nowhere near the dump exit.
^^I tore that piece of **** out after it broke off of the Center Console, and made a Switch Panel that bolts on the under side of the plastic piece that goes around the Radio. Then I put the Switches on that.
I have the one Switch for the Cutout, and I wired in a second one so it doesn't have constant power, I can shut it off since I put it in the Cig Lighter Circuit.
