i cured a problem tonite go me !!!
well i thought maybe the cooler weather had something to do with it but what was happeneing was my gas mileage was HORRIBLE and also i kept on having the SES lite come on at lower RPM's well something told me check to see if anything is loose and sure enough the intake was loose so i retorqued it and i checked the TB too and it was fine and immediately i noticed it was much smoother also i reset the PCM so it hasn't had time to relearn but hopefully by midweek i'll know if this was the problem or not...the manifold was so loose that i had to start all over again at the 44 inch pounds again..its been about 3 months since i did the H/C swap ..are these manifolds notorious for coming loose?
