Short belt mod
Old 12-18-2008, 08:26 AM
firefighter813x's Avatar
Default Short belt mod
I did a search for the short belt mod and could not find the part # or size for the right belt. This mod is just bypassing the power steering, correct? I'm going back to the dyno soon and want to do a test with both belts.
Thanks
Old 12-18-2008, 09:57 AM
the_merv's Avatar
I don't think you can bypass the PS without it messing with the Water Pump, unless you have an electric one..
Old 12-18-2008, 10:50 AM
nemss1's Avatar
5060525 is the part number for the Dayco brand. its a 52.5" belt. i got mine at Advance Auto. the 'shortbelt' just bypasses the powersteering. remove idler and powersteering junk for the shortbelt.
no, u do not have to mess with the stock waterpump to bypass the powersteering
Old 12-18-2008, 11:41 AM
Thanks! I'm going to look at my car now to see what you're talking about.
Old 12-18-2008, 11:48 AM
nemss1's Avatar
no prob bro. i will try to find the thread that has pics of mine
Old 12-18-2008, 11:56 AM
vsocks1's Avatar
Why would you want to bypass power steering? Does't really sound worth it to me....
Old 12-18-2008, 12:03 PM
nemss1's Avatar
less weight, less drag on the motor. for a drag car, its worth it
u can type in P/S delete pics in search and my setup is in that thread
here is a very good pic i found which will give u a very good visual
Old 12-18-2008, 12:35 PM
massls1guy's Avatar
In case anyone wants to do this with an under drive pully looks like you need this one:
http://www.thunderracing.com/catalog...vid=3&pcid=113
11-510K6
"Short Belt" for track use on LS1 F-body with underdrive crank pulley (power steering bypass) $17.99
Old 12-18-2008, 12:45 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running a 51.5 on my car with the Powerbond UD pulley.
Old 12-18-2008, 02:41 PM
Good to know... I have the power bond too. I was looking at my serpentine belt setup and didnt get how you route the belt while still spinning the water pump. Maybe im just a dork... lol
Old 12-18-2008, 03:02 PM
It's worth a try when going to the track! I'll put the old belt on before I go home. I would like to see my dyno/track gains with this. (A/C belt, and PS pulley delete)
Old 12-18-2008, 03:26 PM
bczee's Avatar
seem to me if you had a idler mount somewhere around that open bolt boss (top of the alternator bracket).. it would be better at keeping the belt in contact with the water pump.
Old 12-18-2008, 03:32 PM
slow ride 02's Avatar
Will you be going to the track/dyno soon? I think we all would like to hear the results.
Old 12-18-2008, 03:36 PM
I'd like to go to the track soon, but I don't have drag radials. I'm wanting to re-dyno my car since I installed a new RPM tranny with a tighter converter.
Old 12-18-2008, 03:44 PM
If you need to re-dyno anyways, why dont you take both belts with you and let us know the results?
Old 12-18-2008, 05:14 PM
01ssreda4's Avatar
i agree
Old 12-19-2008, 09:53 AM
chrs1313's Avatar
saw nothing for a gain at the track...absolutely nothing, **** i would take 3hp...my dads car saw nothing too...was worth a shot, did it about a year ago...
Old 12-20-2008, 09:12 AM
That was the plan... lol
Old 12-20-2008, 09:14 AM
I'll take your advice on that one. It seems you've tried to max out your cam only setup.
Old 12-20-2008, 01:59 PM
the_merv's Avatar
Originally Posted by 01ssreda4
i agree
I was thinking the same thing as well, that is just a little too close for comfort.
Quick Reply: Short belt mod
