suggestions on plug wires/boot protectors with headers
Old 12-27-2008, 11:43 PM
demonpixel's Avatar
Default suggestions on plug wires/boot protectors with headers
Hey guys, the LS1 is almost ready for engine dyno day. I put the coil packs on the valve covers today and noticed that all the spark plug rubber boots are cracked all to ****. I have FLP headers and torn up plug boots are a good excuse for me to get some msd wires: http://store.summitracing.com/partde...5&autoview=sku
I've heard of issues from headers melting the wires/boots. I have 6 of the 8 factory metal spark plug boot sleeves, but I found these boot protectors on Summit also: http://store.summitracing.com/partde...5&autoview=sku
Will I be ok with the factory metal sleeves (once I find 2 of them to make a complete set), or should I go ahead and get the msd wires with the Summit boot protectors?
Thanks again
Old 12-27-2008, 11:49 PM
jsteele90's Avatar
i didnt use my metal sleeves and have msd wires. they have not burnt yet
Old 12-28-2008, 12:16 AM
GMCtrk's Avatar
The MSDs can be bent out of the way. Also, if you have a wire hitting a primary it's eventually going to melt no matter what you wrap it in.
Old 12-28-2008, 01:27 AM
demonpixel's Avatar
Cool, sounds like I just need the msd wires then. Thanks guys. If I get paranoid enough, I'll get some Accel spark plug boot protectors from Autozone; they're mentioned in this post: https://ls1tech.com/forums/conversio...s-headers.html
jsteele, how many miles ago did you change to msd wires?
Old 12-28-2008, 01:30 AM
jsteele90's Avatar
hmm about 3k if that, i dont drive the car that much. ive only put 12k miles on it in over 2 years. cant drive it as much as i want when its garaged for 7 months every year, damn deployments
Old 12-28-2008, 01:42 AM
demonpixel's Avatar
hmm about 3k if that, i dont drive the car that much. ive only put 12k miles on it in over 2 years. cant drive it as much as i want when its garaged for 7 months every year, damn deplyments
Sounds like those msds are working out for ya then. You don't seem too worried about the heat.
Just put in my order on Summit; the wires are on their way.
Old 12-28-2008, 03:12 AM
kdavis's Avatar
i have the msd wires also and have no problems. had them about 5000 miles
Old 12-28-2008, 05:13 AM
subhumanzz's Avatar
msd here too. also no problems.
Old 12-28-2008, 10:02 AM
01ssreda4's Avatar
very true. you can twist the msds away from the header.
Old 12-28-2008, 10:07 AM
massls1guy's Avatar
I run those insulated socks on a few of my wires that are close to my headers. I think the brand I got are Accel's. They work well.
Old 12-28-2008, 11:03 AM
demonpixel's Avatar
This forum kicks ***; I feel much better now, thanks all!!
Old 12-28-2008, 01:03 PM
metalmechanic's Avatar
i have kooks with 1700 degree coating, granetelli wires no heat shields, no problems
Old 12-30-2008, 07:44 AM
demonpixel's Avatar
Cool, I think the FLP headers are coated but I'm not sure what the degree rating is for them
Old 12-30-2008, 08:03 AM
chrs1313's Avatar
QTP stainless headers here and my MSD's seem to work pretty good...
Old 12-30-2008, 08:29 AM
Randy WS6's Avatar
MSD 8.5mm multi angle boots
Old 12-30-2008, 09:08 AM
Formulated's Avatar
I've got coated Bassanis. I used MSD wires with fire sleeve, very similar to the protectors you showed, just that it comes in a roll. A few thousand miles later the car still works great.
Quick Reply: suggestions on plug wires/boot protectors with headers
