What mufflers for true duels?
Ok i have true duels 2.5 with a magnaflow x pipe and dynomax bullets dumped. I am going to run the true duels all the way out the back now cause i just lowered my car and i need more clearance.i wanna change mufflers cause i never really liked the dynomax they are raspy with my big cam. What about sweet thunders?
LOL you're not gaining much clearance by going out the back...trust me I know. I personally like the bullets but to each his own. Here's my buds cammed Z w/ sweet thunders.
http://www.youtube.com/watch?v=puUZoHNWLQQ
dont know who you will get to get these out the back...
but, 1 chamber race flowmasters... GREAT air flow.. and sound sick... not raspy at all..
ms4 cam...
http://s250.photobucket.com/albums/g...t=SD531115.flv
http://s250.photobucket.com/albums/g...t=SD531107.flv
http://s250.photobucket.com/albums/g...t=SD531024.flv
http://s250.photobucket.com/albums/g...t=SD531038.flv
http://s250.photobucket.com/albums/g...t=SD531071.flv
ms4 cam...
Yeah well i screwed up and got the eibach sportlines wayyy to low and im gonna get the strano springs instead but im after all the clearance i can get im just after a deep sound that isnt raspy
you need to get an hpipe.. that will change your sound a lot..
hpipe is lower and xpipe is higher.... cant speak for the hpipe.. but the xpipe takes almost all rasp out of most systems... the 1 chambers help with the rest..
Here is my 02 Z28 Hooker LT, 3" TD with H-pipe, high flow cats, One chamber Flowmasters. No eng work other than a port/polished TB
http://kr.youtube.com/watch?v=VV1QWjkobF8
2 full size mufflers fit in the stock location under the gas tank with a little imagination and a welder. With flanges and brackets, it can be easily removed and still retain the bullets and turn downs before the axle if you want it really loud again. The setup in the pic I had Flowmasters after the axle and Powersticks before the axle, recently I removed the truck sounding Flowmasters and replaced them with Dynomaxx Ultra Flo's.
Mainly to cut done on drone. On sweet thunders site it shows a nice setup with thier mufflers. But you car hase some room at the rear to put a set there and quite it down inside the car. Meents has/had a sweet setup a while back for his CME SS.
