Best flowing catback?
Old 12-30-2008, 07:46 PM
02BLKWS6MD's Avatar
Default Best flowing catback?
Whats the best flowing catback on the market? I have a corsa catback setup right now and I've had magnaflow, slp loudmouth 1, and TSP true duals but they were too low. I was wondering if there was something out there that flowed better then what I have.
Old 12-30-2008, 07:52 PM
gsxr1k2's Avatar
I've got my new pacesetter Y and TSP Rumbler for 250.00 right now. Pretty much about straight through. Matt at TSP told me the almost see no difference in hp between the True duals and the Rumbler.
Old 12-31-2008, 08:37 AM
02BLKWS6MD's Avatar
no one else?
Old 12-31-2008, 09:03 AM
teke184's Avatar
what you have flows pretty well. compared to something like the LM or Rumbler you'd probably only see 1-2hp in all reality.
but the BEST flowing catback would be the 4" mufflex...assuming you put a good muffler on it. i think they come with flowmaster
Old 12-31-2008, 09:09 AM
TXZ28LS1's Avatar
i think best flowing would be loudmouth!!! but magnaflow and hooker catbacks are good catbacks as well.
Old 12-31-2008, 09:25 AM
SS1875's Avatar
My Borla flows rather well....I think they are all pretty close . Would be interesting to see if there is any difference between them when installed on the same car and run on a Dyno.
Old 12-31-2008, 10:25 AM
dondb's Avatar
Don't forget to look at the GMMG...it's damn good
Old 12-31-2008, 11:15 AM
teke184's Avatar
and darn $$$
"I think they are all pretty close . Would be interesting to see if there is any difference between them when installed on the same car and run on a Dyno"
agreed and AGREED!
figure the worst flowing catback is probably the flowmaster, and my guess would be you'd still see 10hp over stock. best (3" pipe) catback would be either the loudmouth or rumber, and figure those are good for 15hp.
so with the dozens of choices, and only a 5hp range, go with sound, look, and budget.
or better yet....go TDs
Old 12-31-2008, 11:23 AM
Restricted User
2001 Pewter WS6's Avatar
I only lost 1rwhp with my Corsa compared to the cutout open in the I pipe. This was on a 383 Stroker. The Corsa flows really well...
Old 12-31-2008, 04:29 PM
02BLKWS6MD's Avatar
yeah I had true duals they were really nice but too low. I think I'm just gonna put an electric cutout on the car.
Old 01-15-2009, 08:23 PM
01 BERGER CAMARO SS's Avatar
I think borla, due to the fact you can control how loud it can be with a simple wrench or from a switch if u install an electric cutout. Tips are pretty sweet too
Old 01-15-2009, 08:27 PM
MYSTIC-1SC's Avatar
i would think the lm1 flows pretty well.
Old 01-15-2009, 09:55 PM
C_B64's Avatar
I lose 15 rwhp and 14 rwtq from a cutout to my Hooker Catback
Old 01-17-2009, 01:20 AM
jmilz28's Avatar
4" Mufflex will flow the most, period, most power potential. They are NOT stainless so will rust eventually and have no tips.
Old 01-17-2009, 09:05 AM
omcar's Avatar
Magnaflow is a straight thru design and can't be beat..
Old 01-17-2009, 10:47 AM
SS DNA's Avatar
Smile
I think either a Loudmouth 1 or a GMMG would flow the best.
Old 01-17-2009, 12:04 PM
studderin's Avatar
Also think of the weight, I have a mufflex 3.5 and the thing weight like 2x with my 2OTL weights. thouse things are heavy. Same with some true duels, some of you guys have 70-80#s systems
When I had h/c on my 346, it made 460/408 thu the SLP 20tl, and 466/410 with the 4inch Ipipe open at the end of the TA. Over the smooth blend to 3.5 over the rearend, then 3.25 into the mufflar.
Old 01-17-2009, 12:15 PM
01ssreda4's Avatar
^^^yeah catbacks with full size mufflers can get heavy. i can disconnect my 3 inch duals at the header and hold it and it seems about like thirty pounds but it doesn't even get to the end of the torque arm. the hooker mufflers themselves are supposed to flow really well. i saw a write up one time on flow cfm of mufflers and i believe it was in the top 3 in full sized mufflers.
Old 01-17-2009, 04:01 PM
jmilz28's Avatar
wrong - 3" will not outflow 4". I love the magnaflow but math doesn't lie.
Old 05-17-2011, 01:42 PM
J-Train's Avatar
Bigger is not always better, flow more yes, but there is something to be said for a little back pressure, depending on mods to the car, 3" may make better numbers than 4"
Quick Reply: Best flowing catback?
